Will extra support a 4 barrel progressive set-up.
How do you control the secondary injectors so they don't fuel on closed throttle plates?
progressive throttle body
500 cubic inches, ms extra, 29v, 2.25,four 52# port injectors in an Auto-Nomics four barrel TB
The staged injection feature is for just that purpose. Set it to stage on throttle position, at a point after the secondaries have started to open, and you should be all set.
http://megasquirt.sourceforge.net/extra/stagedinj.html
Roger.
Roger.
1979 Mazda RX-7, running MSnSExtra hi-res 09c for fuel and spark control on a turbocharged, intercooled, and (of course!) injected 13B rotary.
