Car is Neon 2.4 Turbo 2000
MS v2.2 with 29q2
The problem im having is Car been running on MS fuel only for 4 months w/o problems
couple day ago i bought a pair vb921 and followed all the install instructions like 5 times check see if everything was good to go.
THe MS works only if i switch to NEON/MODE after i had start the MS with neon/mode off. once i unplug power to the MS it will not fire back up no fuel VE stay in the 100 constant. with the stim or with the car it give same results
soon i turn NEON/decoder oFF the car starts right up but on FUEL ONLY spark control by Stock PCM like i been driving for months now =(
Anyone have idea what i need to do?
V2.2 Vb921 installed VE Stuck 100 no start problem Help plz
Vehicle: 2000 Dodge Neon
Engine: 2.4L DOHC
Injection: Port 577cc SRT Stage1 Injectors
Description: SRT Built & Turbocharged
Running MS V2.2 Extra 29q2
Engine: 2.4L DOHC
