neon/mode problem VE stuck at 100 no Start problem =(
mula2
Post by mula2 »
Engine descritiption on Signature
problem:
Been driving the MS for 4 months now on Fuel only, few days back i went and solder the vb921 onto it it wouldnt fire car up even if i had Spark control via stock PCM the MS would not fire fuel on NEON/MODE on
I plug stim and same problem. only time it workes is if i turn MS on with neon/decoder off then switch to neon/mode on it works on both Stim and Car but once i turn power off it will not fire back up
the VE stuck at 100 and the middle LED is not firing up the outer LED d17 and d19 are working but not the middle one.
i unpluged the vb921 to see if i had solder some wrong but same result once i switch to neon/decoder the MS will not fire Fuel
MS works perfect on fuel only once i switch back to neon/mode OFF.
Vehicle: 2000 Dodge Neon
Engine: 2.4L DOHC
Injection: Port 577cc SRT Stage1 Injectors
Description: SRT Built & Turbocharged
Running MS V2.2 Extra 29q2
boost junkie
Post by boost junkie »
I've never seen anything like this. When he turns on neon mode the VE sticks at 100. Seems like a firmware issue but he's reloaded. Anyone ever seen something like this?
mula2
Post by mula2 »
Anyone?
Engine: 2.4L DOHC
mula2
Post by mula2 »
Can i get some help plz
Engine: 2.4L DOHC
1seymour
Post by 1seymour »
is soldering in the vb921 the only change you made?
1983 datsun 280zx turbo
ms v3 running msns-e 029q2
input: optical
output: vb921
injectors: pwm
mula2
Post by mula2 »
1seymour wrote:is soldering in the vb921 the only change you made?
yeah the board mod for spark and the vb921 board.
what drives me crazy is that it works but only if i start the car with neon/mode off then switch it to neon/mode on. once MS is powered down no more start.
how can i change the VE to crank lower like in the 40's it may be that is flooding the engine since its stuck at 100?
Engine: 2.4L DOHC
Post by jsmcortina »
I loaded your MSQ onto my Megasquirt/stim and do not see any map oddities it reads 97kpa and responds to a syringe fine.
Have other Neon users successfully shared the crank sensor between the stock ECU and Megasquirt ?
boost junkie
Yes, I'm sharing the crank sensor with the stock ecu. I've never seen the issue that he's having. It's quite strange...
mula2
Post by mula2 »
jsmcortina wrote:I loaded your MSQ onto my Megasquirt/stim and do not see any map oddities it reads 97kpa and responds to a syringe fine.
the Map works fine its the VE table at cranking is constant 100 when it should be 30-50
Engine: 2.4L DOHC
boost junkie
That, and the PW is 0..
mula2 wrote:the Map works fine its the VE table at cranking is constant 100 when it should be 30-50
I don't understand what you are saying. Could you post a datalog of this please.
mula2
Post by mula2 »
Sorry thought i had posted the datalog with the MSQ
Engine: 2.4L DOHC
Have you tested the map sensor with a syringe (e.g. type used for filling inkjets)
The 100kpa reading at the end seems feasible as it reads 99kpa at the beginning before you start it.
I'm guessing that the 104kpa was a backfire??
Are the rpm readings valid? i.e. max of 248rpm
superchargingmachine
Post by superchargingmachine »
I just looked at your datalog it appears to me that you MAP sensor may not be connected to your intake or it is connected ahead of the throttle.
mula2
Post by mula2 »
Still noone can help with this problem?
Engine: 2.4L DOHC
Did you follow the advice given by superchargingmachine ?
