Anti Lag code
Anti Lag code
Is there a version out, would be used with wheel decoder.
... but it sure sounds nice if it's a rally car rumbling thru the forest...
RA40 + 18R + Turbo
MZ10 + 7MGE = track barge!
but is the anti-lag (based on rpm/tps - not a switch) present in the current version?
i'm still at 024 so i'm not sure how the LC works in the later versions (yet).
Considering that an Australian state-level gravel/dirt rally totals ~180km of competitive stages with a total of about 140km of travel between stages... depending on how often you compete, you might only attend 3 or 4 rally events, so the amount of damage you'll do is minimal.
Daily driver use? it would be pointless and futile... and noisy.
tia,
Charles.
tia,
Charles.
RA40 + 18R + Turbo
Marm 247 is an alloy developed by NASA for turbine blanes. Group A teams use (now what we know as WRC cars) Garrett turbos specially designed to take the heat and shock loads of ALS.superchargingmachine wrote:What is a maram shaft? I work with turbo's and I've never heard of that. Personally, I would be more worried about my exhaust valves than the turbo.
