Hi All.
I need direct coil control 2x vb921's, 60-2 trigger support, over-run fuel cut.
I did have MS/Extra 026h8 installed.
But for some resign the 026h8.ini for megatune will not let Megatune load up, and it just crashes out.
If I installed the .ini file for say 029r, 029s, ect, Megatune loads eveytime without fail.
I would like to know witch is the best code to install.
Or should I just install the latest stable version about witch I think is 029q2
Thanks for your time.
Witch extra code to install?
