im using v3 board and going to try out a gm hei 4 pin module.
i currently have my ms wired for vb921 and am wondering what i need to change to make the hei work.
i want to run the signal out the db37 pin #36.
im pretty sure i want to run "top of r26" to ign and disconnect ign from igbtout. i have a few questions about this..
1. what resistors to use between them, if any.
2. wether or not i need the 5v pullup mentioned on the msns setup page. the setup page was for v2.2 board and using fidle output.
3. if i need a 5v pullup, where can i get it from on the board?
4. can i leave ign connected to igbtout in case i switch back to the vb921 later?
thanks
hei4 wiring question
1983 datsun 280zx turbo
ms v3 running msns-e 029q2
input: optical
output: vb921
injectors: pwm
input: optical
output: vb921
injectors: pwm
