How do you scale down a VE table
I'm wondering how you scale down a 12 x 12 table. I see shift and scale. Scale went up but what does shift do?
'65 VW Bus with a Subaru EJ20 Turbo conversion , Air to water I/C , LS coils , 14Point7 Spartan 2 & Solid Air Fuel Ratio 52mm gauge.
MS2 Extra V3.0 board
I just don't want to manually do 144 bins by typing them insuperchargingmachine wrote:In the tuning screen hold the shift key down and use the up or down arrows to richen or lean a point.
To scale an entire VE table open the teble and under tools you can scale based on req fuel.
Is this what you were looking for?
Thanks Lance and SC.
Would changing my REQ fuel from 9.7 to 10 make the car run rich? I made some changes and might have been real time driving tuning with the EGO on above 1200 and it was running fine but did two changes at once. Turned of the EGO and changed my REQ fuel.
