tacho
screamer69
tacho
Post by screamer69 »
is there any way of testing the tacho unit as ive built it and it worked fine for about a month now its stopped working im not sure if its the unit i made or my tacho thats gone up the s***
cheers
2.0 8v turbo 10.7 standing 1/4@136mph on m/s fastest mk2 astra 8vt in europe !!!
2.0 turbo tigra 10.1 standing 1/4 @ 145 mph with problems :( havent turned the boost up yet
check the output with a frequency meter?
screamer69
in english please james !! :oops:
do i have to use the extra parts as im running single coil ???
i had a mess around with it and it seems ok i made up another tacho unit and still the same nothing !!
screamer69
jsmcortina wrote:check the output with a frequency meter?
james i have a function generator thats has external frequency mesurement will that be any good ( im crap when it comes to things like this but willing to lern ) if i can use this what do i do ?????
Something crude like a multi-meter with a Hz setting will also do, or a scope. OR even a volt meter on the AC setting.
screamer69
right put meter on it this morning on settings acv 200 its the lowest setting on there and all i get with driver circuit on it i get 28.8 and nothing else when i rev it it stays as it is
then i did m/s side of it and got no reading so i switched it to dcv and got -0.02 when reved it altered to 0.00 and that was it
any clues whats wrong with it the m/s is running fine i just want the tacho back other wise turbo timer etc dont work
cheers
robert
1seymour
Post by 1seymour »
tach or dwell meter from an auto store would work to see the signal.
1983 datsun 280zx turbo
ms v3 running msns-e 029q2
input: optical
output: vb921
injectors: pwm
slow_hemi6
Post by slow_hemi6 »
Have you checked with megatune that it is still enabled?
Cheers Luke
screamer69
slow_hemi6 wrote:Have you checked with megatune that it is still enabled?
yes its still switched on and i changed the speed to half and still the same thing
im stumped on this one
slow_hemi6
If you get an LED test light at low rpms you should be able to see the led flickering if you probe the transistor base and then the output.Megamanual shows how to make one from a pen case, led,needle,wire and a resistor.That is if you cant get hold of a meter with Hz setting.
Cheers Luke
screamer69
slow_hemi6 wrote:If you get an LED test light at low rpms you should be able to see the led flickering if you probe the transistor base and then the output.Megamanual shows how to make one from a pen case, led,needle,wire and a resistor.That is if you cant get hold of a meter with Hz setting.
cheers ill give that a go and see what happens tomorrow
thanx
robert
