I'm having reset problems only on very low rpm; tickover and slightly above, and often just when I touch the throttle. When it stops I have huge problems restarting the engine especially when the engine is hot. I've never had a reset when the engine is cold, only after it's warmed up.
My system is a lost spark 4 coil pack MSnS with a 60-2 trigger and a Vauxhall/Bosch VR sensor on a 4.0L RV8. The VR sensor is screened which is eartthed only at the MS. I have a LC1 WB sensor and I'm using firmware 029R.
I've put new resistor plugs on, NGK B7ES, I've tried various layouts of earth/ all earths on the engine block/ split the coils earth from the MS earth/ had all the sensors earthed together and split the coil and MS earths. I've tried a 33,000uF cap on the +12V to the MS.
The problem is still there and the main problem is when it stalls when warm I really struggle to restart it which is very embarassing when I have to push my car to the side of the road Toys have been thrown out of the pram i've used a tree branch a'la Basil Fawlty and it still resets so I've come to the end, please help before I comit caricide.
Kev
ANOTHER RESET PROBLEM
Hi Kev,
just out of interest have you tried the VR sensor cables the other way around?
http://www.msextra.com/manuals/MS_Extra ... _Index.htm for MS1 Extra Manuals
http://www.msextra.com/ms2extra/ for MS2-Extra Manuals
http://www.extraefi.co.uk/cobra/accobra.htm 5.0L TVR powered Cobra Replica (MSnS-E)
yep, tried reversing the vr sensor wiring. What confuses me is that it only happens when it's warm and yet I can't find it by cooling individual items.
I've tried a few variations of earthing but ntohing seems to stop it.
Is this reset the same with 36-1 toothed wheel and/or the Ford EDIS module, or is it only60-1 with a 4coil lost spark setup.
Kev
Kev
