Toothed wheel pick up
terrastudios
Post by terrastudios »
Hi all,
I have a renault-based engine and the flywheel arrangement is as the attached picture - does the MSns-E code support this arrangement currently?
Basically the reason why I am confused is the larger "two-teeth-joined-together" typed situation, and how to configure MSnS-E to support this arrangement.
Many thanks in advance
Matt.
Matt Brocklehurst,
TrackLogic Ltd.
Visit our blog http://www.tracklogic.co.uk/ to see our Megasquirt progress on a Megane F7R with ITBs!
This was discussed just a few weeks back and I am fairly sure the answer was no.
terrastudios
jsmcortina wrote:This was discussed just a few weeks back and I am fairly sure the answer was no.
Hmmmmm thats unfortunate, is there any easy method of doing a pick up - the engines assembled in the car, so i don't fancy removing gearbox etc.. to change to a different flywheel!
Matt.
Matt Brocklehurst,
TrackLogic Ltd.
oopsmotorsport
Post by oopsmotorsport »
i have used a signal wheel on the front pully with a ford sensor seems to work ok :)
2.3 saab turbo mid mounted in a seat cordoba{ibiza with a boot}
msne on mostly standard motor ish
