Tach Out -more detail or pictures wanted
Hello
I have a V3 MS1. code 2.25. using 1 output to the dizzy. 6 cylinder engine.
I see the electrical diagram for the tach output but I have limited electronic exp- I bought the board made up.
http://megasquirt.sourceforge.net/extra/tachopin.html
I think seeing a picture of the tach out setup would be a great help if anyone has it or more info on the electrical diagram.
Miles
Miles
If your tacho is from a toyota, you might find that circuit not powerful enough to drive the tacho.
See here http://www.msefi.com/viewtopic.php?t=21005 (scroll down to last post) for diagram that works for older toyotas that get engine upgrades.
RA40 + 18R + Turbo
MZ10 + 7MGE = track barge!
thechuckster wrote:If your tacho is from a toyota, you might find that circuit not powerful enough to drive the tacho.
could i use that one in a 1990 corolla gts because i want my stock tach to work.
