I found this at msd, it says 95-98 on it. Does anyone know if it will fit the escort edis modules?
http://www.msdignition.com/coil_blaster_13_8241.htm
Replacement MSD EDIS coil?
I say "Yes" but I have no first hand proof of this.
The reason I say yes though is i've looked at around one-hundred 4 cyl edis applications and they ALL use the same connector. I also want to say I read a post on here last year sometime where someone used the MSD coil pack. If I were to want the MSD pack I would order it with no worries. You could also be 100% positive if you go to your local auto zone/advence/napa and have them look up the replacement MSD coil pack for a ford escort. The part number should be the same.
Yes, it will work. I have an accel coil on my 97 ford escort. I picked the accel over the msd because its sapose to have little bit more voltage. Im not sure which one is better, but I could tell the differance with it installed. I will also mention some people have had to put risers on their brackets to make them fit, I think thats only on the focus.
