Just put in a very low number (10kPa) and my AE still is not triggering. This was evident from looking at the AE guage and from the datalogs.
It DOES work with TPS triggering, no problem at all. This is what I am currently using as the trigger, but, its not as smooth for me.
Anyone know of this problem yet?
I am using RPM based AE btw. I haven't tried it in standard AE, because, well, RPM based AE works much better for me.
MAP based AE trigger no longer works! What gives?!
MSnS 029t
94 Probe GT custom headers/ short ram intake/282dur cams/modded intake
147wtq@6800/197whp@7700rpms
What changed? When did it work and what did you do to make it not work?
It happened right when I switched over to 29q2 and loaded my old file.
I tried to go in manually and figure out what was different but it all seems the same and doesn't look like its been corrupted.
Is there a hidden setting or something I need to check to re-enable it somehow?
MSnS 029t
