Before you point me to the "search" button, I did and and searched in the forum, unless i am blind...
right,
I am running msn extra with the code 026h4
Dual Table (V8 engine)
Two wideband LC-1 sensors/controllers
When I select "8x8 AFR Target Tables" in Megatune, I only see for VE1 and VE3, but I thought the second wideband was for VE2? no?
So, where can I set the target AFR for the VE2? is there a config file to modify?
Also, how do I log the AFR2 and second O2?
thanks for your time.
dual wideband questions....
Ford 342 stroker | 4inj.TBI
MS2/Extra beta RC3 2.1.0 20090611
Hi
the Dual O2 code is for EGO correction, so it still uses the same VE table and AFR target it simply runs a seperate correcton for each bank of injectors.
As for logging it youll need to edit your msns-extra.ini file, down the bottom of the file youll find :
; These are for datalogging the egt,fuel pressure, GForces, spark angle
; and knock retard. Only 3 can be used at once for MSLVV compatability.
entry = advSpark, "Spark Angle", int, "%d"
entry = egttemp, "EGT", int, "%d"
; entry = fuelpress, "Fuel Press", int, "%d"
entry = KnockDeg, "Knock", int, "%d"
; entry = XForce, "X GForce", float, "%.2f" ; X on X7
; entry = YForce, "Y GForce", float, "%.2f" ; Y on X6
; entry = MAFVolts, "MAF Volts", float, "%.2f" ; MAF on X7
; TEST ONLY - DONT USE
; entry = iTime, "iTime", int, "%d"
; entry = iTimeX, "iTimeX", int, "%d"
; entry = iTimefull, "iTimeFull", int, "%d"
; TESTING
; entry = dwelldelay1, "dd1", int, "%d"
; entry = dwelldelay2, "dd2", int, "%d"
; entry = dwelldelay3, "dd3", int, "%d"
; entry = dwelldelay4, "dd4", int, "%d"
youll need to add 2 lines:
entry = egoCorrection2, "Ego2", int, "%d"
entry = afr2, "AFR2", int, "%d"
also add a ";" infront of 2 of the existing lines, e.g. knck and egttemp,
Phil
; TESTING
Phil
http://www.msextra.com/manuals/MS_Extra ... _Index.htm for MS1 Extra Manuals
http://www.msextra.com/ms2extra/ for MS2-Extra Manuals
http://www.extraefi.co.uk/cobra/accobra.htm 5.0L TVR powered Cobra Replica (MSnS-E)
