MSnS, 2.2 board,
As the subject says. I installed the Dave Cap to get rid if low end tach spikes but then it wouldn't under any circumstances run over about 1000 - 1100 RPM. Dave cap now uninstalled but still have tach spike sto deal with.
Dene
Installed "Dave" Cap now wont run over 1000RPM
Any more details about your setup?
Could be that you have larger than 0.22uF in that or perhaps even if you have the "correct" value it may be too large for your setup. Try half that ( two 0.22 uF in series) or even less.
Got Knock? - see:
Viatrack Printed Circuit Designs (among other things) http://www.viatrack.ca
As you are trying to run spark control do not fit the Dave cap at all - it will alter the timing. You need to eliminate the noise by careful grounding, wire routing and screening.
