Help with coil connections for Vaux C20XE
I appear to be helping a friend squirt a C20XE and need a bit of info on the coil connections...
Anyone know what the pins are on these ?
GM 90443900
Like this
Cheers
GM 90443900
Like this
Cheers
Ian (Spag)
http://www.spagweb.com - http://www.v8mini.co.uk - http://www.pievan.co.uk
"The Roughest V8Mini Deathtrap In The World"
Have you applied a ohm meter to it yet? That looks of the same layout as a Ford coilpack so might have the same wiring.
Hi James
Not seen it meself yet, just trying to get some info to help Dave with loom at the moment.
But yes, it does look a bit EDISish doesn't it!
Ian (Spag)
Cool thanks
I will double check that he has a V3 board with the right bits on...
VR input bits & 2x vb921
Cheers
Cheers
Ian (Spag)
pin 1 = 12v
pin 2 = ground
pin 3 = coil 1 & 4
pin 4 = coil 2 & 3
i havent tryed it but i was given this info for my coil pack it was taken of migweb so its 100 %
or get the amped one from an astra or corsa and dont use the vb921s
(another thing i havent fitted yet )
pin 2 = ground
pin 3 = coil 1 & 4
pin 4 = coil 2 & 3
2.0 8v turbo 10.7 standing 1/4@136mph on m/s fastest mk2 astra 8vt in europe !!!
2.0 turbo tigra 10.1 standing 1/4 @ 145 mph with problems havent turned the boost up yet
[quote="screamer69"]pin 1 = 12v
pin 2 = ground
pin 3 = coil 1 & 4
pin 4 = coil 2 & 3
quote]
He he,
The pic only has 3 pins
pin 2 = ground
pin 3 = coil 1 & 4
pin 4 = coil 2 & 3
quote]
He he,
Ian (Spag)
