I have some trouble to get EGT logging working properly. During first tests I noticed that readings are a bit strange. At room temperature readings were slightly too high and at high temperaturtes readings were clearly too low. At first I thought that thermocouple amplifier would be the reason but its output looked right. For troubleshooting I configured the Megatune to show raw ADC values of EGT input and then I fed 0V and 5V directly to processor pin. The raw ADC values for these voltages were 14 and 153 instead of 0 and 255. So clearly there is something wrong.
All other analog inputs works just fine and all supply voltages are ok so I think that there isn't anything wrong with the PCB. I have also tried another processor with same results. Any ideas what could be the reason?
Oh, I almost forget to mention that I'm using MSnS-E 029q with MT 2.25.
Weird EGT readings
Weird EGT readings
Arttu
when you checked this was your ground connected to the same ground point as the MS ECU?
Phil
Phil
http://www.msextra.com/manuals/MS_Extra ... _Index.htm for MS1 Extra Manuals
http://www.msextra.com/ms2extra/ for MS2-Extra Manuals
http://www.extraefi.co.uk/cobra/accobra.htm 5.0L TVR powered Cobra Replica (MSnS-E)
