Help with Triggle Angle setting please
I just strobe my actual timing against what MS thinks and found that there is 10 degree difference: when I fixed timing to 10 degree BTDC, my timing light lines up with TDC.
My current setting is: triggle angle=50 degree, Trigger A=1, return 6. Trigger B=13, return 19. Trigger C =25, return 31.
Does it mean that if I simply change the trigger angle to 40 degree, it should line up?
The main question: I think I'll run a max of 36 degree BTDC. Would 40 degree trigger angle be ok? If not, if I change it to 60, does the following trigger look ok -
Trigger A = 35, return 4. Trigger B = 11, return 17. Trigger C = 23, return 29? I'm using time based cranking so I guess trigger return really doesn't matter either?
thanks.
thanks.
With timebased don't fill in the return teeth.
Yes, you would be better stepping back over the missing tooth and using no.35 as trigger A to give a larger trigger angle.
Yes, set the trigger returns to zero.hobieboy wrote:By don't fill in means put 0 in all 3? And does my 35/4/11 triggers look ok then?
The triggers should be 35, 11, 23 from your previous post. Check with a strobe.
Hi James,
Very strange - I changed the settings to 35,11,23 and set trigger angle to 60.
Verified with timing light that all cylinders' (4,5,6) timing are same as what MS thinkgs.
But now she won't idle well - my RPM oscillates by 300. Changed back to 1,13,25 and trigger angle of 40 then she's happy again: RPM osciallates <100.
Any idea?
It also looks like I won't be needing more than 30 degree timing so am inclined to stick with 1,13,25 & trigger angle of 40 if MS can handle that.
Any idea?
Really? No "vacuum advance"? My table goes up to 51deg.hobieboy wrote:It also looks like I won't be needing more than 30 degree timing
Mine is a turbo so at high load/high rpm situation, everyone I talked to suggested around 15-18 degree timing.
And I think the factory ignition curve has timing max-ed at ~32 degree.
If I can make MS to work with 60 degree trigger angle, I'd like to but not sure why setting trigger A to 35 (B=11/C=23) will cause idle to be very unstable.
