026h8 v 029q2 : issue when engine warmed up
hello all,
I am trying to decide, which code would be best to use?
the old one 26h8 or the latest one 29q2?
thanks for your time
**edited title**
**edited title**
Ford 342 stroker | 4inj.TBI
MS2/Extra beta RC3 2.1.0 20090611
Hi there,
029 has a small issue with the ASE and Warmup that is in the middle of being cured, 026h8 works as close to 100% as possible, thats why I sent your MS to you with it, but 029 is a better code and Iam using it, so the answer is use 029 and if you find it doesnt work for some reason let us know and go back to 026h8,
Phil
p.s. see this note before upgrading: http://www.extraefi.co.uk/software/MS_Note.doc
Phil
http://www.msextra.com/manuals/MS_Extra ... _Index.htm for MS1 Extra Manuals
http://www.msextra.com/ms2extra/ for MS2-Extra Manuals
http://www.extraefi.co.uk/cobra/accobra.htm 5.0L TVR powered Cobra Replica (MSnS-E)
Thanks Phil,
I have installed the 29q2 hires 8e, and it works great apart from one thing (same with all the code i am using i think, unless there is a setting that i have missed ).
so i think i will return to 26h8 (well return, i will try it... )
026h8 v 029q2
What is the one thing?
KeithG
Posted by email.
KeithG
Posted by email.
the "thing" is:
I start the car fine, it idles more or less ok (it's a V8 with a wild cam....) warm up to normal temperature.
You can blip the throttle, engine willl revs up and down fine.
then the thing: you blip the throttle a little bit more and the engine revs will not ho down, they're stuck at different rpms (1200, 1400, 1500 etc...) you have turn off the engine.
if someone could tell me what;s wrong.... argh
cheers
cheers
This is true. Thoguh I had a few problems with stick IAC valves and also with the ingition computer (which also controlled the IAC valve) holding the valve open ready to "catch" the falling revs - if you were *just* unlucky it would catch it too well and the fuellign computer would fuel for the open IAC and it never dropped.
like the others said, it sounds like more air is getting through than you would like. EIther through a gasket, sticky throttle, or something. If you are running PWMIdle closed loop, I would look here. First try 'warmup only' which is open loop control just to see what is going on. Either that, or just close off the AIC somehow and get a base tune first.
KeithG
KeithG
I will check that tonight, you might be right now that I think about it.newtyres1 wrote:I back up what Mario says. Since it's a fuel only setup then the butterfly not returning fully would raise the idle
Ian.
edit:
Just thiniking of something else, I have looked for leaks and I am 99.99% sure there are none.
If I had some if would occur everytime I blip the throttle, but it's a random one.
So the sticky throttle might be the last thing to check.
I may have fixed it
I have checked the throttle plates, and 2 of them would not close correctly. not by much, just a little but that's enough to cause chaos i think.....
well i could not start the engine as it's late....
I might test it tomorrow, if that's has curred my issue, then on the road i will be.
