Now the fun begins...
hobieboy
Post by hobieboy »
Well, after a very long road, finally took her out for the 1st time for a 3 minute ride - everything went well. So, the real fun (tuning) begins now hopefully :D
Many thanks to all who helped so far, particularly James :P
The one lesson I did learn is: try not to rebuild the engine, then try MS with fuel & spark at the same time. Maybe start with fuel. And in my case, I'm also running 6 VB921 with direct coil control. But at least most things seem to be functional now (still have to test/use the 2nd coil once I get another set of ignition wire for my twin plug).
