Someone said to me that after loading msns-e code for the first time, i do not have to use the "bootjumper" when upgrading to a newer msns-e code ?
Is this correct ?
Haven´t trusted that advice yet....so i´m still using it when changing code version.
upgrading questrion
upgrading questrion
Peugeot 309GR1990 XU9JAZ(4cyl 1.9litre) 10.8:1 CR with 60-2 VR wheel decoding ,V2.2 card, singel coil and dizzy spark ,360cc 0 280 150 431 injectors. Msns-E hi-res 10d2 and E85(Ethanol) in the gastank.
upgrading questrion
This is true. After you have MSnS-Extra in - no need for jumper.
Petteri
snillet kirjoitti 22.08.2006 kello 09:56:
Petteri
Posted by email.Someone said to me that after loading msns-e code for the first
time, i do
Is this correct ?
Haven}t trusted that advice yet....so i}m still using it when
changing code
version.
Peugeot/Citroen XU5 BDZ(4cyl 1.6litre) engine with 60-2 VR wheel
decoding
singel coil and dizzy spark and Magneti Marelli(solex) TBI. Msns-E
029q and
That SO much makes it easier for me to upgrade , since the box i fixed into the stock ECU mounting behind the dash
