Code 029 and forward
Mt ver 225
Settings
distributor msns
Fidle idlecontrol
Led 17 sparkoutput A
PWm idlecontrol
Algorythm PWM
It worked ok until my idlespeed valve broke down 2 months ago.
Then i moved some wires and used this setting.
distributor msns
Fidle sparkoutput A
Led 17 squirt
PWm idlecontrol
Algorythm PWM
And the fuel pump startet to turn on and of the second time i startet the engine, the first time it ran perfekt.
I couldnt find the problen then. And startet all over with the default settengs.
No conflikt.
Today i tryed to implement the idle code again, but the new valve i also broken.
So back to the old settings
distributor msns
Fidle sparkoutput A
Led 17 squirt
PWm idlecontrol
Algorythm PWM
The same thing fuelpump turns on and of the second time i set the ignition on.
Opend miniterminal.
and it said i couldn't use
Fidle both as spark and pwm idle.
d*** i know that and i didn't
Then i changed my settings to this
distributor msns
Fidle sparkoutput A
Led 17 squirt
PWm idlecontrol
Algorythm B&G on-off
And there was no conflikts.
There must be an fault in the software somwhere, in my humble opinion.
BR
Morten
A code conflikt that dosn't exsist
Volvo 245 turbo
B 23 et engine
MSnS-E hires 10g
B 23 et engine
MSnS-E hires 10g
What is the fault in the software? Sounds like it correctly identified a configuration error to me.
You have set:
FIDLE = spark output A
FIDLE = PWM idle
You cannot have both so it reports a config error.
JAmes
You have set:
FIDLE = PWM idle
JAmes
