I have V3 MS1 with 029s, using 1 spark output for the orignal dizzy.
Everything was running fine on my 911 but one day the MT didnt load up so I went to download 029s and now I get a flashing fuel pump error, when I turn it off and back on again. I went to the mini terminal as in the FAQ and it says I cannot have more than 1 spark output defined.
In the outputs all I have is 1 output, if I switched of the MSnS , its fine I have played around with the outputs to see if there is any change but no luck. I have copied my outputs.
Please help, I have tried reinstalling the .s19 file also.
Thanks!
Flashing FP -read FAQ, Dont understand the Mini Terminal
You do not have the required permissions to view the files attached to this post.
