another 4300 rpm thread
I got the same thing going on right now.. I have NO idea what is wrong at this point.
My VR signal looks clean all the way across the rpm range. I also have 3 coilpacks. Car runs GREAT until then though. Nice snappy throttle.
My car won't go past around 4100rpms and it start breaking up and popping and just acting terrible.
I *DO* know if you are using a VR signal, you might have to tweak the resistance values somewhat on your signal conditioner. I have been spoiled by using a hall effect until now so its like starting from scratch.
MSnS 029t
94 Probe GT custom headers/ short ram intake/282dur cams/modded intake
147wtq@6800/197whp@7700rpms
No, I severely doubt it. If I creep up to 4300rpms, my car starts popping and acting very badly. There is something else going on here.Jon k wrote: What would be a safe amount of timing to run on a 4v per cyl 6 cyl motor - I see a max of about 9.5 psi of boost - the CR is 10.0:1.
I haven't even tried to setup accel enrich... so maybe that's the issue?
I am starting to wonder if its the wheel decoder settings..
I am using this:
DIS6 replacement
36-1 wheel aligned the same as EDIS6
trigger angle=70
Timebased cranking and 10deg cranking angle.
trig A=35
trig B=11
trig C=23
Use three VB921 to drive the coils and set LED17,LED18,LED19 as spark outputs.
Spark output "inverted"
Dwell control with 5ms cranking, 4ms running and a 0.1ms min discharge.
Exactly how it is in here. I locked timing to 10btdc, looked at it with a timing light and its ROCK SOLID until 4300rpms, then it goes crazy.
Just for kicks, I am going to try A=11 B=23 C=35. Maybe I have no idea of what I am doing, but I am losing my mind right now anyway so...
I have tried changing the lm1815 circuit, but its working rock solid also, I really don't have a clue just yet. Something that MS doesn't like is going on here and I can't nail it down yet.
MSnS 029t
Re: Car drives fine until about 4300 rpm...
Yes, I used the stock one.. I dunno though, maybe I should put a big electrolytic on the coilpack. Can't have too much capacitance on the coilpacks.Keithg wrote:you do have caps from the coil 12V supply to ground, don't you? There was a post about that recently. I tried to run wasted spark and would get WOT misses as well. It was better with 025 style wheel decoder instead of 024 (36-1 wheel). I did not add the caps, but that would be a hlep. I am sure you are already running resistor plugs.
$0.02
KeithG
Posted by email.
Swapping the VR leads caused the car to not get a tach signal, so I guess thats not it.
I will probably have to somehow mess with the gap on the VR sensor is the only other thing left.
MSnS 029t
Yes, actually.. It can't be turned around or I get no tach signal at all, so that makes it easy to figure out.shaodome wrote:Ion...so far in every KL powered car, the VR wires i've seen are solid green and blue coming out of the same black shield. Just to confirm, your using the green wire as the tach input and the blue to ground, correct?
I have the gn wire to the tach, and theblue wire to ground. If I switch them around, I get no tach signal at all.
MSnS 029t
Nope, pulled all that stuff out. Still running VB921s with my EDIS coilpack. Since no one had ever had COPs running before, I eliminated them first. I have a really nifty connector to the harness so I can switch back very quickly. ;)shaodome wrote:Hrm...in wonder if this has something to do with the COP ignitors you have hooked up...
Besides that, my COPs are dummies.. They don't have an integrated ignitor or anything, you still need an external ignitor to drive them, they are merely coils.
Ummm, man, I am feeling stupid now....
Uh c11, thats supposed to be removed isn't it?
MSnS 029t
No offense man but this is my thread and you're sort of hijacking it to the point where we're all getting confused.ion332 wrote:Nope, pulled all that stuff out. Still running VB921s with my EDIS coilpack. Since no one had ever had COPs running before, I eliminated them first. I have a really nifty connector to the harness so I can switch back very quickly. ;)shaodome wrote:Hrm...in wonder if this has something to do with the COP ignitors you have hooked up...
1992 BMW 525i M50 Non Vanos 24v Turbocharged
Stock COP Wasted Spark
MS2/E v3
MS2/E v3
Or hijacking it to the point that your car is now work properly. ;)Jon k wrote: No offense man but this is my thread and you're sort of hijacking it to the point where we're all getting confused.
It goes that way sometimes, in the confusion you pick something out that seems good and you try it and it works.
MSnS 029t
I think my issue is a a REALLLLLLLY rich tune causing hesitation/misfire on boost. I also am running stock temp plugs. I have a set of cooler plugs in the mail.ion332 wrote:Or hijacking it to the point that your car is now work properly. ;)Jon k wrote: No offense man but this is my thread and you're sort of hijacking it to the point where we're all getting confused.
MS2/E v3
MS2/E v3
Well, I got mine working now too, only thing is that I had to switch the 36-1 wheel out with a 6-1 wheel.
Once the 6-1 wheel was on there, it worked ok in the upper rpms, but I lost some throttle response. Im sorta bummed on that, but, hey, the car works and I can swap over to the 36-1 wheel at a later time.
MSnS 029t
