First drive in my MSnSe 911 Turbo! But got towed home....
After 10 months working on getting MS to run the spark on my '94 911 Turbo... it fired up! I am still using the original fuel CIS system for now.
Many thanks to everyones help esp James & Bill.
I have been driving it up and down my street to test it all out and all has been been fine, So yesterday I took her for a drive and about 10miles into it all was going fine and then it just cut out! A french policeman gave me a helpful push off the road ( Im living in Paris)
So I tried to start again but nothing, if I let the fuel pumps run a bit on their own then cranked it, it fires up but then just instantly dies without coughing and the pressing the pedal doesnt help.
I have checked spark and pulled an injector- all is fine and working.
After getting towed home I tried again as the engine was a bit cooler but same thing as above- it fires up easy but dies instantly. I hooked up the laptop and all the guages seem ok, rpm ok and spark advance ok.
Any ideas at all?
Info:
Porsche 1994 911 Turbo CIS Fuel
MSnSE V3 MS1
MT 2.25 with 029s firmware.
VR sensor with 60-2 trigger wheel.
Any ideas at all?
Info:
MSnSE V3 MS1
check to make sure you have correct injector settings. It will do that if you have high-z injectors, but MS set up for low Z.
Just one possibility
Peter Florance
First Fives.Org - The E12 Registry
1981 Euro BMW 528i w/3.5L & Megasquirt Fuel Injection
1981 US BMW 528i "Repo Car"
http://www.firstfives.org
mailto:peter@firstfives.org (peter@firstfives.org)
ssr# 284
From: Miles965uk [mailto:miles.stovold@edftrading.com]
Sent: Tuesday, August 29, 2006 4:06 AM
To: megasquirt-mss@msefi.com
Subject: First drive in my MSnSe 911 Turbo! But got towed home....
I have driving it up and down my street to test it all out and all has been benn fine, So yesterday I took her for a drive and about 10miles into it, it just cut out! A french policeman gave me a helpful push off the road ( Im living in Paris)
I have checked spark and pulled an injector- all is fine.
After getting towed home I tried again as the engine was a bit cooler but same thing as above- it fires and dies instantly. I hooked up the laptop and all the guages seem ok, rpm ok and spark advance ok.
Any ideas at all?
Info:
MSnSE V3 MS1
This post is at:
http://www.msefi.com/viewtopic.php?p=139539#139539
Posted by email.
Peter Florance
ssr# 284
Any ideas at all?
Info:
MSnSE V3 MS1
This post is at:
Posted by email.
Peter Florance
PF Tuning
81 BMW Euro 528i ESP Car
PF Tuning
well, you need compression, fuel and spark to run and you seem to have all 3. The next thing is timing and amount. Verify that the timing is OK on the spark. Could something have moved? You said it sat for a while during the spark install, could the CIS system be giving fuel, but not enough fuel? How about too much (really not too probable unless the flap is locked open). CIS is pretty simple and robust. Could your VB921s be getting too hot? If you are set for generic wheel, wasted spark and MT shows RPM, you should be getting a signal in Next check it on the stim like Shawn says and check spark output as well with leds across the VB921s or some other method (scope, relay). What are your dwell settings?
KeithG
KeithG
Thanks for the responses and help!
Boostjunkie, I will try it on the stim but will have to buy one so it wont be for a short while.
Peter: The coil driver seems to be fine and not overheating.
KeithG: Thanks I will look at the timing when its cranking and when it fires up to see if it doesnt move. I have pulled an injector and tried pressing down on the air flap and the fuel seems to flow fine as it was before.
I have had the car starting and running fine for a few weeks but this was my first long drive.
Im trying to think of this logically because I really believe the fuel is ok, however it really only starts and dies when I pre run the fuel pumps (I guess it builds pressure). But the flapper is not sticking and injectors seem to be ok. I have bridge the fuel pump relay too.
I will check the timing and see to eliminate that. I thought if the injectors were playing up then it would splutter and not die instantly...
I will check a few more things and get back.
How do you know that the VB921 was not overheating? Reason was - I blew 2 of them when I first tried to start the car and I had a low-tech, inccurate temp sensor sitting beside them to monitor just in case they went hot.Miles965uk wrote: Peter: The coil driver seems to be fine and not overheating.
I suggest you measure at least the resistance across the B-E & C-E junctions to make sure its still ok.
When you checked the plugs, did they look ok, i.e. there were sparks & fuel?
Maybe try some new plugs to make sure you still have both fuel & spark.
actually I was thinking the opposite problem.
If you use 'peak-hold', meant for low injectors, on high z injectors, they may not stay open except during cranking
Peter Florance
ssr# 284
Peter Florance
ssr# 284
Posted by email.-----Original Message-----
Sent: Tuesday, August 29, 2006 9:07 AM
This post is at:
http://www.msefi.com/viewtopic.php?p=139564#139564
Peter Florance
PF Tuning
PF Tuning
Ok just for more info:
The CIS and the injectors are not EFi or run by MS and the injectors are run constanly by the air plunger.
I am using the stock dizzy still and with one VB291, I will test to see the resistance for the overheating but it sparked fine.
I will try and fire it up tonight to see what happens.
Oh then disregard my advice on injectors. ):
It's possible if the dwell is too long the VB921 can overheat and shut down?
Peter Florance
ssr# 284
Peter Florance
ssr# 284
Sent: Tuesday, August 29, 2006 10:49 AM
This post is at:
http://www.msefi.com/viewtopic.php?p=139596#139596
Peter Florance
PF Tuning
PF Tuning
