tach spike conquered!!!!!!!!!!
Finally, I'm rid of the tach spike beast!!!
used peter florance's circuit and it all went away...
never did find the download(and I looked a lot!!)
Found it in some vast search of spikes
Suddenly everything seems to respond as it should and it's running fairly well, course now I'll be starting all over...
Also found that bumping the PWM up to 85 made a huge difference in how it runs, instead of starting at 75 for low Z and going down??
Still haven't figured out how to get the AE bars to move more than just a very small amount, I would think that if you hit the throttle all the way with MT on but not running that it would simulate AE by moving up the scale(tps or MAP)???
What a Great threshold to pass, Peter if our paths ever cross pints are on me. Thanks, Mark
500 cubic inches, ms extra, 29v, 2.25,four 52# port injectors in an Auto-Nomics four barrel TB
Re: tach spike conquered!!!!!!!!!!
Pints! I'm there!floppy wrote:Finally, I'm rid of the tach spike beast!!!
I'm guessing the download feature is still broken.
I'll post it one of my sites and post it with the link so it can be found by searching.
Someone emailed me for it (I hope I remembered to email it to them) and I had a heck of a time finding it. Lots of references to it on the web (Turbobricks and Alfa) but not the actual file. It's on my PC at work and I'll get it to an accessable place.
Note I think it's more complicated than it needs to be, but I just ran out of time to engineer it any further.
Glad it helped!
Peter Florance
PF Tuning
81 BMW Euro 528i ESP Car
PF Tuning
Peter Florance's Tach Circuit (what it tends to be called on the web)Keithg wrote:please post a link here to this solution.
KeithG
Sorry for the long URL:
http://www.firstfives.org/faq/ljet/mega ... 021505.PDF
Peter Florance
PF Tuning
PF Tuning
This is for fuel-only systems that are triggering from the negative terminal of the coil. I ran with it for a couple of years with nary a hicup.Dr.Hess wrote:Yes, please. More details. I get a spike occasionally too.
Like I said, it's too complicated but I ran out of time to make it simple and elegant.
The PDF refers to V2.2 board components
Peter Florance
PF Tuning
PF Tuning
Thanks for posting that. I don't think that's what's causing mine. I'm using VR off the factory dizzy with 2 teeth cut out and I trigger 2 igniters, basically, to two waste-spark coils. Spikes just happen. Sometimes at high RPM sometimes at lower RPM's. At higher RPM (6-7K), the spikes might register as 10-20K. At lower RPM's, they might register as 6K. Doesn't seem to be associated with anything else like my VVT, which comes on at 4400 and off at 4300. Oh well.
Asking again, as I think the questions are not clear on my last post:msoultan wrote:Just so you guys know, I'm still running Peter's mod and it works great on my 78 vw bus (40,000 miles later). I am still forever grateful to Peter for that mod. It saved my life! ;)
thanks,
mike
D8: can I keep the 5.1V, or it must be changed to 4.1V?
C11 and C12... it`s not show in the Peter schemattic, and not in the picture in the PDF... so, I need to get it off de board??
thanks for your help..
Yamaha XT600E (big single)
MS-I, V2.2, MSnS-E HR (fuel only mode), Palm M105...
They can be left in or taken out. Should not make any difference either way.Fritz-XT600 wrote:V2.2 sch
Changes:
- D5 => 4.7k resistor
- R10 => 4.7k resistor
- include Dave Cap betwen R10 and D3
Some questions:
- D8 must be changed from 5.1V to 4.1V ??
- What about C11 and C12??
Thks
Peter Florance
PF Tuning
PF Tuning
