LM1815
c_turbo
LM1815
Post by c_turbo »
What for the LM1815?
I have a 60-2 tooth weel with a VR sensor. With a MS-I v3.0 MSnS-E
thanks!
MS-I v3.0 MsnS-E
029v
sportage4x4
Post by sportage4x4 »
with a v3 pcb you dont need a LM1815 if you only have a crank sensor.
1990 Mazda Miata: GM Gen3 V8 swap, 4.8L, custom cam, 2x GT2860R turbos, MS3 + MS3X.
2003 Kia Rio wagon: Mazda B6T/G25MR swap, Miata CAS, IHI RHF5 @ 2bar, LSx truck coils, P&H board, boost control.
rs2000
Post by rs2000 »
sportage4x4 wrote:with a v3 pcb you dont need a LM1815 if you only have a crank sensor.
I thought you needed the LM if you had a VR sensor, be it a crank or distributor pickup (Unless using EDIS or HEI). I thought it turned the pulses into a square wave for megasquirt..
muythaibxr
Post by muythaibxr »
you only need the lm1815 if you're using a 2.2 board... the v3 board already has the circuitry to convert a single VR input into a +5v square wave.
c_turbo
Post by c_turbo »
Thank you for yours answers
I was thinking the same thing that you, but talking with a friend and the doubt appeared.
In short, don't need a LM1815 with a MS-I v3.0
Thanks!
MS-I v3.0 MsnS-E
029v
