I'm using 029v and RPM-based accel enrichment. When I'm in the "low RPM" range and stab the throttle, my accel enrich gauge shows -333% enrichment. It does this no matter how I adjust the RPM or enrichment values. When the engine is cold, there is some awful hesitation to go along with the -333% reading. When hot, there is no hesitation and the engine is "snappy", just like it should be.
It doesn't exhibit this behavior in the mid or high RPM ranges.
Is this just a bug in the gauge? I've had my enrichment so high the engine actually bogged but it still showed -333%.
Negative acceleration enrichment?
Re: Negative acceleration enrichment?
I'm also having problems adjusting TPSAE. I will attach a log and a tune. most throttle events have my AE going negative, and not adding fuel, and one even shoots up to 2350%! I wanted to add that my MAP DE stays on all the time no matter what. I'm no sure if its pulling fuel or not. The car drives fine but has a stumble that I cant seem to tune out. I've read on other threads that this issue is common on MS1/Extra 029y3. Has anyone found a quick fix for reliable accel enrichment on ms1extra?
77 datsun 280z mostly stock
megasquirt v3 board
ms1/extra 029y3 code
msns, tpsae, lc2 wideband, speed density
turbo distributor
z31 coil
240sx ka24 tps
2004 ford focus idle valve
original datsun clt
same clt sensor for mat
anybody wants my tune just ask for it. ;)
megasquirt v3 board
turbo distributor
z31 coil
240sx ka24 tps
original datsun clt
Log with more aggressive timing and more accel enrich pw.
megasquirt v3 board
turbo distributor
z31 coil
240sx ka24 tps
original datsun clt
megasquirt v3 board
turbo distributor
z31 coil
240sx ka24 tps
original datsun clt
