jsmcortina wrote:That's the problem...
the high compression is making the missing tooth indistinct. Take a look at the tooth log and compare it to the examples in the manual. By eye the tall missing tooth is quite unclear and is not double the length of the tooth that follows it due to the compression slow-down.
Two ideas, you might want to do both.
- rotate the trigger disc so the missing tooth region is 2-3 teeth earlier (that will put it in the high-speed "dip" in the tooth log)
- remove one more tooth to make it a -2 wheel (remove the tooth that would pass the sensor before the missing region)
For either of these changes you'll need to re-set your tooth#1 angle.
Users browsing this forum: Google [Bot] and 1 guest
