Gremlin is winning.. (strange miss)
Re: Gremlin is winning.. (strange miss)
Very weird log - it looks like the signal sometimes drops out completely. Maybe a bad solder joint in the RPM input circuit?
This is a Super420a unit from RS-A. I can try to reflow the solder points for the input circuit and see if it helps.
Any chance you could explain what you found in the logs to indicate the signal is dropping out completely? Here is a small snippet of the log. It would appear the numbers indicated below are the ones in question, but I'm really not sure what I'm looking at other than a value of time in micro seconds.
Code: Select all
ToothTime Time
us us
2500 5857429500
2700 5857432100
2600 5857434600
2700 5857437200
2700 5857439700
2700 5857442300
2440100 ? 5859882500
2600 5859885100
2700 5859887600
2600 5859890200
2360900 ? 5862251000
2700 5862253600
2700 5862256100
2600 5862258700
2426800 ? 5864685600
2600 5864688100
2700 5864690700
2600 5864693200
2421600 ? 5867115000
That is correct; it's tooth time in microseconds. And 2,440,100 microseconds is like an eternity when it comes to the times you should be seeing. That's a loss of signal for over 2 seconds.
Got it.
I reheated two points that I feel my equipment can safely do. Anything more then these two and I'll have to get it back over to RSA.
I'll let you know how it goes after I drive my car to school tonight.
Here's a pic of the two points I attempted:
Looks like the tach input circuit is some sort of proprietary RS Autosport deal. Unfortunately, I have no information about what they used, and I'm not sure RS Autosport is still in business.
Yea, its proprietary and most people I spoken to suggest removing it to allow the upgrade to MS3. I may end up sending this unit out for that upgrade, specially since I really want a working IAC so I don't kill the motor when I turn the AC on at idle.
As for the resolder last night... A new tooth log shows the same "glitch" as before. What I do not understand is how the MS unit can go two seconds between crank signals and remain running. Error control of some kind?
Ted.
Ted.
you wouldn't by chance have a slightly bent tigger wheel could you. i drop mine once and it rolled down my leg barly hitting the ground hard and it got bent ...
