MSQ for 1.8 - 2.0 Vauxhall/Opel Astra/Kadet
Hi there
I have been ring MS1 V3 on my jag V12 for some years, but now I have changed the injectors from the low impednace 450cc ones to Siemens vauxhall red top 250cc injectors.
So I am after an MSQ I can use to get the fuelling nearly right so I can at least getting it ticking over. At the moment it ticks over at 2000 rpm + and is running as rich as hell!
The engine has just been rebuilt, with bigger turbos, decomp plates custom plenums etc.. here is a video of its first run.
http://youtu.be/2146IkiHxUs
Please
Kind regards
Nick
Please
Kind regards
Nick
kind regards
Nick
Twin turbo Audi V8 Zonda inspired thing
Nick
Re: MSQ for 1.8 - 2.0 Vauxhall/Opel Astra/Kadet
Hi Nick, I do not see why you want a Vauxhall MSQ ???, if your previous MAP was fine all you need to do is redo your Req Fuel with latest Inj's info and retune, Regards DMnicktruman wrote:Hi there
Please
Kind regards
Nick
Thats the problem, I set the constants up with the 250cc inj info and that uis fine, but the fuel table is still way out. As the car is not road legal, I cant get it on the road to tune it (easily).damon308 wrote:Hi Nick, I do not see why you want a Vauxhall MSQ ???, if your previous MAP was fine all you need to do is redo your Req Fuel with latest Inj's info and retune, Regards DMnicktruman wrote:Hi there
Please
Kind regards
Nick
I just want to see where a 1.8 engine is so i can gauge where best to set my table. I lowered all the values yesterday by 10 and it ceratinly helped. Cheers Nick
kind regards
Nick
Nick
Did you already try the "required fuel calculator" and "generate table" options in Megatune? Those worked out fairly well for me.
hi, Yes I have, thats fine, the issue is with the fuel VE table, its set up for 400cc injectors. It would be good to see a 1,8 astra/kadet file to see what is a good base onfig for the red top injectors. I dont think they have been used in a twin turbo V12 before!!BMW528e wrote:Did you already try the "required fuel calculator" and "generate table" options in Megatune? Those worked out fairly well for me.
the last working MSQ is attached
kind regards
Nick
Nick
The VE table shouldn't need changing (that's the whole point of it being a VE table.)
Just adjust the ReqFuel number and injector dead time.
The turbos are not connected yet, its 5.3l V12 with twin V6 coil packs. The injectors are 250cc vauxhall red tops.
kind regards
Nick
Nick
Are you using a TPS? There is something weird going on with TPS accel in your log.
Yes I am using the Jag's TPS sender, it reads backwards (inverted). But its always been like that.BMW528e wrote:Are you using a TPS? There is something weird going on with TPS accel in your log.
Can you tell me how do I set up injector dead time and the correct PWM? I used a calculator and workied out the settings (see attached PDF) but can not see where or how to put these into megatune or tuner studio freebie
kind regards
Nick
Nick
Jag V12 Re: MSQ for 1.8 - 2.0 Vauxhall/Opel Astra/Kadet
Hi James
I have cover to cover many times, but I have been told I need to entre dead time parameter?
Cheers
Nick
kind regards
Nick
Nick
Yes you do. What's the problem?
Maybe it is that MS1 says "opening time" when it really means dead time ?
I am sorry James, I didnt understand.
kind regards
Nick
Nick
