MS1 V2.2 Bosch 2 wire high idle
Postby boostin » Thu Sep 20, 2012 1:17 pm
Hey again
Just a quick question, kinda got my self confused and want to make sure I hook this up correct.
I have a MS1 V2.2 extra ECU and want to run a bosch high idle valve and have seen several ways to wire it up and not sure what is the best. One of the ways I saw was to get the power from the fuse box after the main relay then to the idle valve then use the ecu to gound it.
Is there a different way?
also i got kinda confused about reading about having to install a transistor in the ecu, does that apply to my set up?
Thanks for reading and helping
mike
1989 Mitsubishi Mighty Max 4WD 2.6 MS1 V2.2
1989 Mitsubishi Mighty Max 2WD lowered 2.6 Weber 38 soon to megasquirt
1993 Eagle talon TSI Soon to megasquirt
boostin
Re: MS1 V2.2 Bosch 2 wire high idle
Postby Matt Cramer » Fri Sep 21, 2012 6:08 am
boostin wrote:Hey again
mike
If you mean a two wire PWM IAC valve, that is how to install it, and you will need to upgrade the IAC drive transistor. See this link for details.
http://www.msextra.com/doc/ms1extra/MS_ ... .htm#Fidle
Postby boostin » Fri Sep 21, 2012 9:24 am
Ok, I get it now as far as the ecu goes.
What about how I had the rest of the wiring set up where the ecu controls the negative side, is that correct?
boostin
Return to MS1/Extra support
