Before I used to use Megatune, and I remember it was pretty complicated to change the settings for type of oxy-sensor.
My question is. Now when using Tuner Studio; is it correct that it is much easier to swap between the sensor types? Is it just to change in the menus of TS?
/Lars
Oxy-sensor?
Re: Oxy-sensor?
It is a bit simpler, but the exact procedure depends on what MS version and firmware you have.
Re: Oxy-sensor?
I have ms1v3 and the latest ms-extra code (which is pretty old I believe). Don't remember y29, something
/Lars
/Lars
Re: Oxy-sensor?
In this case, you specify the O2 sensor type in the Settings tab of the Project Properties window.
Re: Oxy-sensor?
/Lars
/Lars
