This is possible correct? I was told it was and am having a hard time figuring it out. I tried searching and couldnt find out how to do it. Can anyone offer help? anything appriciated.
-Roy
Using TunerStudio with ms1 HELP!
Re: Using TunerStudio with ms1 HELP!
I think we are going to need more information here! Exactly what kind of problem are you having using TS with MS1?
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
My problem is that I can get my computer to link to my MS. through megatune, but not through tuner studio. I'm trying to find out if anyone here with an MS1 uses tuner studio, or if anyone knows how to make them operate together
I used ms1 with tuner studio but only with 029y4 firmware. What firmware is on your ms1?
What EXACTLY happens when you try to connect TunerStudio to your Megasquirt? Did you go through the steps of creating a new project and using Detect?1badgpz wrote:My problem is that I can get my computer to link to my MS. through megatune, but not through tuner studio. I'm trying to find out if anyone here with an MS1 uses tuner studio, or if anyone knows how to make them operate together
Im not sure what firmw. is on it currently, I was trying to put the new firmware on it (the 09 one that was mentioned above) But then somehow when I downloaded it to my computer, I couldnt unzip the file? It said my winzip trial was expired, and its a somewhat older ish computer running windows 7 so I have no idea how it wouldnt have that. But yes I came to the conclusion Its got to be that I do not have that firmware in my MS. because I did the detect and everything and my computerr could not find it.
And thank you guys for helping me and responding btw!
-Roy
-Roy
- Running MSx/Extra
If you still have Megatune open you will not be able to link through Tunerstudio,close Megatune and re-try..
John
P.S Where are you?
John
P.S Where are you?
