Table switching & Alpha-N : AFR target 2 uses KPA, solved..
Hi everybody,
recently I decided to try table switching, as the 12x12 VE table was too small for my aplication.
so I have VE1 for 600-3900 RPM and VE3 for 3600-7300 RPM and two identical AFR target tables, one for each VE table.
I would rather have one AFR target table for both VE tables, but I do not know how to do it.
as you can see in attached scatter plot, everything is OK until 3900RPM, but then AFR targets stop following the table over 3900 RPM .
blue dots on the left side - 12.8 afr, green dots on the right - 14.8-15.1
help please ...
help please ...
Re: AFR target does not follow table..
MSQ
If you're not hitting your AFR targets, you need to retune your VE table.
Hi Matt, I'm glad you are here, but i wish you were more helpful
my VE table (tables) are 95% complete, but I wanted more resolution in low RPM area, so I'm triyng table switching.
VE table 1 for low rpm until 3900, VE table 3 for 3600-7400 rpm.
VE table 1 and AFR target table 1 works as expected, as you can see in the left side of the scatter plot, there are green dots representing 14,7 AFR in crusing area, yellow dots in overrun area, and blue dots in WOT area.
But after it switches to VE table 3 stange things happen..
as you can see in the right side of the scatter plot, it's almost all green (14,8-15,1AFR) except overrun area.
AFR target for WOT shoud be 12,8 over whole rev range, but it's not !
I have no idea where are those nubers coming from, but it's not from my AFR target table for VE 3.
So my VE table is tuned for 12,8 AFT at WOT, but over 3900, MS is targeting to 14,8-15,1 AFR, ego correction is leaning mixture down, I'm asking why ???
thanx for any input, sorry for my english.
My mistake - I had thought the plot was of the AFR and not the AFR Target. Can you post the actual log that came from?
I think I have got it, there must be a bug in HR code, I'm running in Alpha-N mode, but AFR target table for VE3 table is running in speed-density mode...
How do I fix it ?
How do I fix it ?
Found a difference between VE1 and VE3 AFR targets in MSNS-EXTRA.ASM
look at those pictures, diffrences highlighted..
I think there should be "AlphaTarAFR" instead of "TPSTargetAFR" under "NO_TPS_SetAFR2"? what do you think ?
If so, can I just edit ASM file, recompile with new ASM, load new S19, is it that simple ?
Alpha-N : AFR target uses KPA, code writer needed.
solved.
Re: Table switching & Alpha-N : AFR target 2 uses KPA, solve
Please explain how you solved this as I need to use this setup as well.
i
thank Gavin2swe wrote:solved.
i
open file MSNS-EXTRA.ASM in notepad. ( it should be in Program Files/MegaSquirt/msns-e_hr/src directory )
find " NO_TPS_SetAFR2: "
it looks like that:
replace "TPSTargetAFR" with "AlphaTarAFR", it would now look like this:
save the file and close notepad.
do a backup of "MSNS-EXTRA.S19"
execute "compile.bat" in "src" directory, it will create new "MSNS-EXTRA.S19" in "msns-e_hr" directory
now you can connect your laptop to MS, save your tune, load firmware (msns-e_hr/download-firmware.bat), load saved tune back.
thats all..
BTW: this bug affects all available code versions (HR10g HR11d and 029y4a), but only if you're running Alpha-N and table switching.
I had a talk with Phil Ringwood, so I think it will be fixed soon..
it looks like that:
Code: Select all
NO_TPS_SetAFR2:
clrh
clrx
brset TPSTargetAFR,feature7,AFR2_AN ; Have we selected to use
; tps for target afrs instead of kpa?
lda kpa
bra AFR2_STEP_1
AFR2_AN:
lda tps
Code: Select all
NO_TPS_SetAFR2:
clrh
clrx
brset AlphaTarAFR,feature7,AFR2_AN ; Have we selected to use
lda kpa
bra AFR1_STEP_2
thats all..
There aren't any plans to release any new MS1/Extra codes. It was retired in 2007.
I don't think anybody will release new code with new functions, but fixing known bug is not that much work, I'd do it just for good feeling..
Thanks Gavin2swe wrote:open file MSNS-EXTRA.ASM in notepad. ( it should be in Program Files/MegaSquirt/msns-e_hr/src directory )
it looks like that:
Code: Select all
NO_TPS_SetAFR2: clrh clrx brset TPSTargetAFR,feature7,AFR2_AN ; Have we selected to use ; tps for target afrs instead of kpa? lda kpa bra AFR2_STEP_1 AFR2_AN: lda tps
save the file and close notepad.Code: Select all
NO_TPS_SetAFR2: clrh clrx brset AlphaTarAFR,feature7,AFR2_AN ; Have we selected to use ; tps for target afrs instead of kpa? lda kpa bra AFR1_STEP_2
thats all..
- Running MSx/Extra
I'd do it to stop people wasting the past week trying to use/tune table3 to AFR 2 and then trawling the forum to find a clue why my tune wasn't following the AFR table.......back to table 1 for now...
Thanks 2swe.
John
Thanks 2swe.
John
