Hello, my car sat for 5 years with MSnS 1-extra before I finally finished it last year. Now the car sat since last year until now, and the only thing I did not finish on the wiring/setup side was the Fan Control. I had a guy off of another forum add the feature to the ECU, However, I have nothing showing what output it was installed on and even how to get it running properly through MS. My question was, does anyone know how to I can figure out which ouput it was installed on and even how to get it going properly through MS with setting it up correctly?
Thanks in advance,
Mike
Fan Control
Re: Fan Control
Search the board for one of these:
http://www.msextra.com/doc/ms1extra/MS_ ... tm#outputs
Then see how it's wired up.
Re: Fan Control
Your best bet would be to open it up ant take some piks. And posibly upload an msq
Re: Fan Control
Have a look on the PCB and see if you have a wire connected to the JS0 hole. That is the usual example given to wire up a fan to make use of Output 4 that has the Fan on and off temps in Tunerstudio.
Good luck,
Doug
Good luck,
Doug
http://dggt6.blogspot.com.au/ Memoirs of a Megasquirt Triumph.
