Fan Control
widersturbo
Fan Control
Post by widersturbo »
Hello, my car sat for 5 years with MSnS 1-extra before I finally finished it last year. Now the car sat since last year until now, and the only thing I did not finish on the wiring/setup side was the Fan Control. I had a guy off of another forum add the feature to the ECU, However, I have nothing showing what output it was installed on and even how to get it running properly through MS. My question was, does anyone know how to I can figure out which ouput it was installed on and even how to get it going properly through MS with setting it up correctly?
Thanks in advance,
Mike
Re: Fan Control
Post by Matt Cramer »
Search the board for one of these:
http://www.msextra.com/doc/ms1extra/MS_ ... tm#outputs
Then see how it's wired up.
mazdaspeed
Re: Fan Control
Post by mazdaspeed »
Your best bet would be to open it up ant take some piks. And posibly upload an msq
dggt6
Re: Fan Control
Post by dggt6 »
Have a look on the PCB and see if you have a wire connected to the JS0 hole. That is the usual example given to wire up a fan to make use of Output 4 that has the Fan on and off temps in Tunerstudio.
Good luck,
Doug
http://dggt6.blogspot.com.au/ Memoirs of a Megasquirt Triumph.
