Hey guys, super noob here working on his first MS project
current setup is on a 1966 corvair, using a GM TBI setup, and ford EDIS 6 ignition.
the car will start, sputter, and die all over the course of about 2 seconds, When the car dies, megasquirt also looses connection to my laptop, This connection is regained again after
earlier tonight, i reloaded firmware, and started over to see if that could fix it, it did not
uploaded is the file i am currently working with, and the log file from a crank and die out, Any help is appreciated.
First startup, need help
Re: First startup, need help
Any chance it's using non-resistor spark plugs? Those can cause all sorts of issues, and are common on older engines.
