First off, thanks to everybody who has helped me out on the last project, i ended up getting the car running pretty good on GM tbi, and edis, once the erractic voltage issue was solved, things came together fast
However i have an interesting dillama, Since the car is non turbo, and its an older car, with a big camshaft, it only pulls around 78kpa of vac at idle, this means i have 3 rows to edit in my VE/Spark map between what is idle, and WOT. Is there any ways to change the axis information for these maps, that way i can have a higher resolution over the area i am working with?
IE make it so the 12x12 VE map, operates between 40, and 100kpa, (increments of 5kpa) rather than 20, and 150kpa? (increment of 10 kpa)
map sensor resolution
Re: map sensor resolution
Yes, just type in the numbers that you want.MikeDTuned wrote: Is there any ways to change the axis information for these maps, that way i can have a higher resolution over the area i am working with?
i didnt know that feature existed, Thanks for your help!
