HELP WITH IGNITION 4EFTE
I'm starting the Insatalacion a MS1 (ems-pro, 029y4) and when they get to the step of combining position sensor into doubt this ignition has 3 different options for example the wheel is 24 teeth but the bottom also has a single tooth with a gradual slope, with a connection of 4 options (NE, G1, GE YG) but the truth and that which is not the correct combination (which also is not the combination of it that corresponds to the sensor reads 24 teeth ). We ask you to please help me make the best combination and if possible let me know what the best settings in the system. Thanks I await your prompt response
Re: HELP WITH IGNITION 4EFTE
If your budget allows, upgrading to an MS2 will handle the stock distributor much better - see this link for how MS2 does it:
http://www.msextra.com/doc/ms2extra/MS2 ... utors.html
With MS1, your best bet is to grind one tooth off the 24 tooth wheel and use the missing tooth decoder.
