Hi all! I'm running a MS1/PCB3.0 on my boosted Honda CRX. I'm using 029y4 firmware.
Some days ago I've noticed some misfires and glitches when boosting (~12/15 psi). When running on low MAP loads everything is fine, so yesterday's night I've logged a bit and then...
As you can see, suddenly duty cycle goes near 0 without any reason, is this a noisy condition?
This is my current tune and my last log
Today I'm going to do some cable management and improves to my Megasquirt.
Thanks in advice,
Possible noise condition?
Re: Possible noise condition?
Duty cycle going to zero generally indicates a fuel cut of some sort, such as a rev limiter.
Yep..... Dropping to zero at ~7400 rpm.... right where he has it set in his msq!Matt Cramer wrote:Duty cycle going to zero generally indicates a fuel cut of some sort, such as a rev limiter.
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
Oh, I'm a fool.
Sorry about that, btw I know I have that misfires so I'll keep testing.
Hi everybody! Following with my noisy problems, I've tested other Megasquirt I was building for a friend, so I've loaded my MSQ, then cranking and it runs very well!
I've made some pulls and everything work'd fine, so I plugged in my Megasquirt again, and everything works fine again!! So, my problem is around my messy wiring installation.
