Possible noise condition?
nano
Post by nano »
Hi all! I'm running a MS1/PCB3.0 on my boosted Honda CRX. I'm using 029y4 firmware.
Some days ago I've noticed some misfires and glitches when boosting (~12/15 psi). When running on low MAP loads everything is fine, so yesterday's night I've logged a bit and then...
As you can see, suddenly duty cycle goes near 0 without any reason, is this a noisy condition?
This is my current tune and my last log
Today I'm going to do some cable management and improves to my Megasquirt.
Thanks in advice,
Re: Possible noise condition?
Post by Matt Cramer »
Duty cycle going to zero generally indicates a fuel cut of some sort, such as a rev limiter.
kjones6039
Post by kjones6039 »
Matt Cramer wrote:Duty cycle going to zero generally indicates a fuel cut of some sort, such as a rev limiter.
Yep..... Dropping to zero at ~7400 rpm.... right where he has it set in his msq!
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
nano
Post by nano »
Oh, I'm a fool. :lol:
Sorry about that, btw I know I have that misfires so I'll keep testing.
nano
Post by nano »
Hi everybody! Following with my noisy problems, I've tested other Megasquirt I was building for a friend, so I've loaded my MSQ, then cranking and it runs very well!
I've made some pulls and everything work'd fine, so I plugged in my Megasquirt again, and everything works fine again!! So, my problem is around my messy wiring installation.
