Single coil BIP373 control
TomppaHe
Post by TomppaHe »
Can I run BIP373 straight from FIDLE output like Crane XR700/3000 here? http://www.msextra.com/doc/ms1extra/Diz ... lev2.2.htm
Maybe with extra pullup resistor as advised for Bosch ignition units here? http://www.msextra.com/doc/ms1extra/MS_ ... .htm#bosch
Here is how it's normally done for BIP373/VB921 http://www.msextra.com/doc/ms1extra/MS_ ... nglecoil22
The reason I want to do that -> I'm replacing XR3000 with externally mounted BIP373. I controlled it from FIDLE so I have wiring done from pin 30. Modifying the DB37 connector and car harness is very difficult. Small modification to pcb would be easy but I would like to keep the pin 30 for ignition control. I could cut the pcb copper and run the line from other side of R16 but if that's not necessary I would prefer keeping the pcb intact.
Background info: MSExtra code on V2.2 board, single coil, Crane optical trigger.
Thanks!
Re: Single coil BIP373 control
It could be driven from FIDLE if using a 100 to 330 ohm pull up resistor. Set spark output inverted to no.
TomppaHe
Post by TomppaHe »
Thanks! I'll try that.
TomppaHe
Post by TomppaHe »
Matt Cramer wrote:It could be driven from FIDLE if using a 100 to 330 ohm pull up resistor. Set spark output inverted to no.
Sorry I need to make sure I don't fry anything...pullup resistor would be in parallel with D9, that is to 12V. Just feels that 100...330R is kind of low there? Did I understand it right?
dontz125
Post by dontz125 »
The base signal for a BIP is 5v through a 330 Ohm resistor. What you're setting up is to turn the transistor permanently on, then turn it off by grounding the base signal with the FIdle circuit.
TomppaHe
Post by TomppaHe »
dontz125 wrote:The base signal for a BIP is 5v through a 330 Ohm resistor. What you're setting up is to turn the transistor permanently on, then turn it off by grounding the base signal with the FIdle circuit.
Ahaa, so I need to pull it up to 5V, not in parallel with D9 which is connected to 12V. I was thinking that way I would mess up the 12V and 5V circuits but...yes D9 prevents that.
