MS1, 3,57 BOARD, MODIFIED FOR 2 COIL OUPUTS, MAP-DADDY BARO.
I've pulled this off the shelf after a few years to finally start the install. I'm trying to do initial bench test to make sure everything is ok, when I connect with tuner studio, I get a configuration error. I can't seem to figure out where it is. I'm using the megastim and I seem to remember the last time I had this hooked up, if I had it set on generic wheel mode, I'd get an error. I can't seem to get it to reset to back to a state that will allow for testing.
Any help would be appreciated.
Basic Configuration Error - Stim Based?
Re: Basic Configuration Error - Stim Based?
What is the config error message?
Please upload your MSQ as an attachment. (See the Forum help page.)
OK. Here is the MSQ.
I can't get it to display the specific error. I will try it a few more times.
