First Install wine.
Wine seems to run with DOSBox, and execution of the download-firmware.bat runs too fast to allow you to select a COM port before it defaults to COM1. I couldn't be bothered trying to fix that. Instead I just ensured that a symlink had been set up to point the USB-serial device file at COM1. First determine the USB device's name. Plug in the USB-serial device and run:
Code: Select all
dmesg
Code: Select all
ln -s /dev/ttyUSB0 ~/.wine/dosdevices/com1
Code: Select all
wine start download-firmware.bat
