MS1, Extra V-3
The canister purge valve I am using is normally open. when the engine is cold it wants to close the valve and then open it when warm.
How do I change it so it applies voltage and closes the valve when warm?
I've looked in the Manual but can't seem to find the answer.
fast idle valve Control
Re: IAC Control
If the purge valve is an on/off valve, use a generic on/off output instead of the IAC.
Re: IAC Control
Thanks Matt,
I have it selected in TS as B&G on off. I think this is correct.
I need it to open the valve when cold, close when warm. Right now it does the opposite.
Re: fast idle valve Control
Use one of the programmable on/off output circuits for this valve instead of FIDLE.
