Map sensor drops to 67kpa when the rpms go over 400, this happened on the stim board when no vacuume is being applied. It is also linked in with the injectors operating simultaneously untill 400rpms then switching to alternating.
If it helps, the last update i did to the board was installing a Tip 120 transistor in Q5, it seams like this issue evolved directly after this change, What did i do wrong?
Attached are the current file, and datalog from the stim board
Map sensor drops to 67kpa when rpms go above 400
Re: Map sensor drops to 67kpa when rpms go above 400
You have set it to use a fixed MAP value for the first 5 seconds after startup - see Startup / Idle -> After Start Enrichment Settings.
Thanks a bunch! still so much to learn about MS!!
