To start, Thanks everybody on the forum, i know i post a lot of problems, and i appreciate the advise poeple on here give
Secondly, here is todays battle.
I am having an issue with (what looks like in megalogviewer) the TPSacc coming in and out randomly, To check software flaws i reloaded the 029y4 firmware, and quickly set it up for EDIS, and my larger 550cc injectors, and turned the key
the car started and ran, however misfires at random times, below is the data log, and current file on the car. The misfires seam to be direcly corrilated with the TPSacc phasing in and out. Any ideas why are welcome
TPSacc
Re: TPSacc
i am using TPS based enrichment, so all the MAPdot setting are closed off. Maybe i am just looking in the wrong spot?
Re: TPSacc
Since i hate threads that dont have a resolution posted, Here is how i resolved the issue
The route cause was Electronic noise, i had all my grounding points attached to the alternator bracket. (including ones for the cooling fan, and main chassis) After some research it became apparent that the alternator emits quite a lot of noise, After re-grounding MS, and sensors 1 foot further away in the engine bay to the intake manifold, the issues seam to be resolved!
thanks again for the help, Im sure it wont be long until im stuck again!
