Ignitor trigger signal issues
vrtigo
Post by vrtigo »
Hi guys,
Have had my MS running on my 4AGE with distributor for about 3 months, pretty solid! Yesterday I drove the car to the shop and back, no problems. Today I try to start, no spark. After checking fuses and wiring, I swapped out for the factory ECU, and it fired right up. Im using a harvested ECU connector which Ive soldered wires to the back of. I then tried measuring the cycle rate of the trigger line at the ECU connector with my multimeter - got a solid 12.3hz, which equates to around 360rpm, spot on. So the signal seems to be firing ok. At first I thought the ignitor transistor had fried. Could it not be passing the right voltage/current to trigger the ignitor? I dont have a scope to check with unfortunately, and its difficult to judge a square waves voltage with a MM.
No data log, youll just have to trust me that Im getting rpm. Its an MS1 with v2.2 board, using the distributor settings. Must stress that its been working fine for 3 months now, and nothing has changed. Im leaning towards the ignitor driver has probably popped. What does this sound like to everyone else?
Re: Ignitor trigger signal issues
Post by Matt Cramer »
Does TunerStudio see RPM while cranking? Does the output LED pulse off and on?
vrtigo
Post by vrtigo »
Yes.
And yes, the LED is flickering when I disconnect the ignition wire and set to inverted.
:msq:
vrtigo
Post by vrtigo »
What else could you possibly need to know? Set up using MSnS Distributor mode, it was working fine, suddenly not. Ive given you the symptoms. Its purely a hardware problem. Guessing is what I want you to do. Take a stab and suggest some avenues that I could pursue based on the information provided.
vrtigo
Post by vrtigo »
FYI this did turn out to be a popped ignition output transistor. Had it blow a few times after this, until I decided to put a diode inline after it in the loom - no more problems.
