Ms1 No RPM
Ms1 No RPM
Im running ms1 on my vr6 turbo and when attached to the car am getting no rpm signal at all. With the jim stim attached I can sweep my rpm smoothly but am still getting zero rpm when attached to the car. Anyone have any ideas were to start?
Re: Ms1 No RPM
What sort of trigger wheel are you using?
Can you post an MSQ and a tooth log of an attempted start?
Re: Ms1 No RPM
im using the factory vr6 wheel which is a 60-2, ill post up an msq later when im home, im getting no activity on the tooth logger when attempting to start
Re: Ms1 No RPM
both my trim pots are fully ccw still seeing no activity on my tooth logger
Re: Ms1 No RPM
Try recalculating your trigger return points - they don't look right.
http://www.msextra.com/doc/ms1extra/MS_ ... #wheelsoft
